1 members (klhansen),
160
Mod | | | Forums66 Topics128,132 Posts1,056,729 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21039 07/08/2002 11:57 PM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | I'm trying to track down back wheel cylinders for my '42 1.5 ton Chevrolet truck. They are "huck" type, inch and a half bore. Parts books seem to stop (going back) at '46. Will the '46 and up work? What is the difference between '42 and '46? After stumbling around on the web, the many links found here all seem to be more focused on the half ton trucks. How about a good link to a vendor that knows the big old trucks?  | | |
#21040 07/09/2002 12:58 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Splash, I bought rear wheel cylinders for my 45 2 ton from Jim Carter.They are 1-1/2 inch diameter. | | |
#21041 07/09/2002 1:09 AM | Joined: Feb 2002 Posts: 21 Member | | Member Joined: Feb 2002 Posts: 21 | Splash, Have you considered having the cylinders machined out and sleeved back to standard? Might work out a fair bit cheaper. Bob  | | |
#21042 07/09/2002 2:03 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I had the same problem looking around the web in that if you don't have an AD 1/2 Ton, there is almost nothing for your truck. However I saw small notices on sites such as Carter's that said we do have parts for the larger trucks, call us. I guess the catalogs are for the large demand items. | | |
#21043 07/09/2002 2:30 AM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | Jim Carter does not have 1.5" bore wheel cylinders for huck style brakes listed in his online catalog. Will have to send a message... I think it costs around $85 plus shipping to sleeve a large bore wheel cylinder. It's a good investment since new ones that old (huck style) and large bore are very hard to find. Right now I would be happy to find a couple core castings to send off for sleeving. Then I would have them onhand when the hubs and drums come off. There is nothing worse than getting the truck in pieces without the parts to put it back together.  | | |
#21044 07/09/2002 4:46 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Good Luck! I'm looking too. Need front ones now. Obsolete Chevy site had some listed. Chevy Duty has some listed, cheapest of bunch. SEems like one little thing or year or ? was diff from mine. I have a number here for obsolete parts place, needs to have GM part # to find/look in stock. It's Vintage Parts, Beaver Dam, WI 1-877-vintage or 1 877-846-8243 Lots easier to find Obsolete parts places for old Phords than GM's. Why is that? Also, try Bow-tie Bits, he's done me good on other big truck parts, has used and NOS sometimes. Let the rest of us know. Oh, I think the cylinders are all the same up to 50 on most big trucks. I'm thinking sleeving is more money than NOS parts, just you don't have to look for them. Some sleever's use stainless, others like White Post use brass. Either better?
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#21045 07/09/2002 5:42 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | try chevs of the 40\'s they have a couple listings for rear of ton& 1/2 and 2 ton. shows most brake stuff being 37 up same. I had good luck w/ them for my 46 ton & 1/2. Bill | | |
#21046 07/09/2002 8:29 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | If you are in a scrap yard ,, the casting # is 5300892 , for the 1 1/2" Cyl. (part # 5300885 if that helps) The trend seems to be to sleeve in stainless as that material does not score as easily as the brass does. And yes they are the same '37 - '50. | | |
#21047 07/09/2002 11:51 PM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | Thanks all for the help. I'll be better armed with information as I renew my search.  | | |
#21048 07/10/2002 1:06 AM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | One new request: can anyone provide the casting and part #'s for the left rear? I think the numbers Dusty provided are for "right rear." Remember numbers can make or break you!  | | |
#21049 07/10/2002 6:42 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Oil,doesn't matter for left or right on 50 or older. 51 and 52 have four cylinders in rear, and they are diff between them, and 53-59 have same type, but diff #'s. I got my #'s from OlBlue on this page. The #'s given above are right. Anything in yards is gonna be too pitted to use, you'll need new or sleeved for those.
#21050 07/10/2002 1:00 PM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | | | |
