4 members (1955 1 Series, Barney1951, Millenimech, 1 invisible), 79 guests, and 2 robots.
Topics128,032
Posts1,055,438
Members48,422
#210318 06/21/2006 3:43 AM
I was lucky enough to have a windshield frame in great shape, that is until I tried to remove the broken glass. Turns out the screws on the bottom of the frame where stuck and broke off in the frame. I know your thinking man are you lucky. But now I can't get the frame apart or the glass out and need help. Any ideas. I can sure use them.
1946 1/2 ton
I'm not addicted I just don't know when to stop
#210319 06/21/2006 4:08 AM
I had that same problem. I drilled out the screws but the center v-support metal inside was rusted solid to the frame. I took a skinny cutoff wheel in a dremel (I think they are 1" in diameter and about a 1/16" thick) and cut a slit across the holes to the edge of the opening in the middle of the frame. That enabled me to pry it open just a enough to get that center v-support metal out. I then had a welder tig weld the slit. Then I blended the weld with a file and redrilled the holes and bought new center v-support metals. Sounds kinda laber intensive but those frames are expensive......like around 300 dollars.
#210320 06/21/2006 4:15 AM
John,
Did you worry about drilling those too far or damaging the threads and not being able to tap new threads?
Brian
1946 1/2 ton
#210321 06/21/2006 5:33 AM
Those center v-supports are available brand new from venders like American Classics. That's the banner at the top of this page. You also might want to look at this page.
I forgot to mention that I tried to install the glass myself. Pain in the ###! I ended up taking to a glass shop, they had some old guy experienced with old cars that did a beutiful job.
