4 members (Jack Ryan, Craig /49 Panel, Otto Skorzeny, 1 invisible), 73 guests, and 2 robots.
Topics128,083
Posts1,056,326
Members48,442
#210304 06/20/2006 10:58 PM
Junior Member
Junior Member
I have a 1949 3100 with some OLLLLD retreads. Time for some new rubber.
Current tire size on the recaps reads 7.75X15 on front and 8.45X15 on rear.
Truck VIN plate shows 4600# GVW and then the shop manual I have says "15-6 or 8" for that GVW. Lower GVW's show "6.00-16-6" and "6.70-15-6" for 4200 GVW, and "6.50-16-6" for 4500 GVW.
I'm confused!
I'm not going to haul much weight in this old 'bolt, just want a smooth ride for running around town...
What size modern tires would you recommend?
Thanks!
#210305 06/21/2006 12:35 AM
Hi,I put a used set of LT 215 / 85 R16 BRIDGESTONES on my 1950 Canadian built 1300. I am using the original 16" wheels and had to install new radial tubes. I picked the 4 up and had them installed and balanced and they seem to work fine. The big problem was finding a modern radial truck tire that was that narrow . You may find it easier having the 15 " rims .good luck , Jeff
#210306 06/21/2006 11:38 AM
Junior Member
Junior Member
What do you think of 165-80-15's?
Are these tires same circumference than originals?
Thanks!
#210307 06/22/2006 4:14 AM
Junior Member
Junior Member
I think I am now leaning toward 225 75 15
Anyone have any thoughts either way?
