8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible), 58 guests, and 1 robot.
Topics128,049
Posts1,055,699
#210283 06/20/2006 3:47 PM
Still don't know how to post pics so maybe the link will work. Have you ever seen a dual point set-up such as this 327 in a 55 2nd has.
http://buzztrader.com/showad.cgi?1081&1955704111NC_295_12632.dat
Open the link and see the pic of the engine.
The truck is for sale thru a place in NC. I emailed them asking about the set-up but as yet haven't heard from them.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#210284 06/20/2006 4:04 PM
Bruce - can't post links to yer hard drive! grin need to have the pic hosted somewhere on the net
Chev did have a dual point dist available in the 327 years, used on vettes I believe - Mallory made one too
#210285 06/20/2006 4:08 PM
Bill,
Email me here at work, [email protected] and I will send you the link from the site. This is like no ordinary dual point setup I have ever seen. A strange one. Maybe you can post it for others to see and comment on.
Bruce
#210286 06/20/2006 4:12 PM
Maybe try this link then see the pic of the engine.
Bruce
#210287 06/20/2006 4:23 PM
The link didn't work for me but a dual point setup is not unusual. There were several company's that used a dual point dist. Ford,GM,Chrysler,and Datsun used them there may be others.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
#210288 06/20/2006 4:46 PM
Link changed in original posting. Try again.
Bruce
#210289 06/20/2006 5:06 PM
Thats a wierd setup,have seen many dual point distributors,but never 2 distributors.If your gonna update the best way to go is an HEI dist.I replaced the dual point dist.in my 350 SB,with an HEI.Have never had any trouble with it.
#210290 06/20/2006 5:14 PM
I hate to be negative, Folks, but I suggest you guys with point type distributors store them away somewhere. I did. You know an EMP type detonation will knock out those delicate electronic distributors.
#210291 06/20/2006 5:33 PM
this post has got nothin to do with point distributors vs something else, kid, it has to do with what the heck is this??
that's NOT a factory vette 327 setup Bruce, this is - even the highest rated original 327's had one dual point distributor
never seen anything like it or any parts advertised to make it fit the block - what's running the front one? where do all those plug wires go? who makes an intake that configuration?? you can see there's single wires on single plugs, but there's 16 wires from the 2 distributors! I'd be interested in hearing the story if they come back with one
#210292 06/20/2006 5:41 PM
That's a dual-distributor setup. My head ain't believin what my eyes are seein. In order to use this, you'd have to have a second gear at the front of the cam and two plugs per cylinder. The last time I looked at a smallblock head, there wasn't a heck of a lotta room to put another spark plug orifice. And I don't see anything that looks vaugely like 2 plugs or 2 wires near each stock location.
Admittedly I haven't seen anything like every setup that's available but what I HAVE seen is show cars with a lotta non-functional stuff on them to look kool.
Ok. So I called the salesman and he said it was a "special race car setup" that used a special timing cover and a gear that bolted on to the front end of the cam to drive the front distributor. He also said that the rear distributor is not being used. There's only one plug per cylinder. He suggested removing all the trick stuff and puiting a stock timing chain cover on and then using the rear distributor only.
I sure don't think I'd pay $30 grand for it. Especially with what appears to be puke-green variegated shag carpeting from the 70s.
But they say that there's an *** for every seat.
#210293 06/20/2006 5:51 PM
hahaha a very spendy way to have the distributor more accessible for setting the points! grin
#210294 06/20/2006 6:32 PM
I'm like you other guys, I never seen anything like that. I first wondered if it was just a dummy put on there for looks somehow. I'm familiar with Gateway Classics - their main/first store is across the Mississippi River from St. Louis just a couple of hours from me. Everything they sell is on consignment. Check out their own website Gateway and see the prices.
Professional Novice
#210295 06/20/2006 8:15 PM
Hey, I was accused of doctoring a photo to get this pic. Me who can't even post a pic here
Bruce
#210296 06/20/2006 11:18 PM
I've never seen one like that either. Kind of hard to believe.There is only one plug wire on each plug.I think it's more of a show !!!!
1951 3100 Chevrolet
#210297 06/21/2006 1:01 AM
That's definitly a weird setup. I know a local rodder that has a front mount ditributor setup like that on a small block in a '39 Pontiac. His only has a front distributor with a dummy shaft in the back to run the oil pump.
Bill Burmeister
#210298 06/21/2006 9:03 AM
Valve train technology has come a long way. Years ago the components were heavier and they used massive triple valve springs. Roller cam followers were heavy and they would add springs inside, under the head. All of these springs plus a high volume oil pump were twisting the cam and changing the dist timing. This was before crank triggers, and the front dist was one solution.
'67 GMC 3/4 292 4spd
