2 members (Hotrod Lincoln, greenie-reddy), 96 guests, and 2 robots.
Topics128,049
Posts1,055,741
#210269 06/19/2006 9:38 PM
This may have been posted before, if so my apologies upfront as I couldn't locate the discussion thread.
I just bought a 1956 and am looking to update the front suspension. I've recieved mix information regarding Mustang II's front suspension kits (some same they work well and others say they are too light). What is this forums' general consensus?
Also, what GM front ends w/ 11" spindles fit a 1956 Chevy truck? I've heard talk of 70 - 81 Nova / Camaro front clips and also various model year Caprice Classic front clips.
Let me know your thoughts.
Thanks!
Paul
1956 Chevy Task Force Webshots
My wife puts knots on my head faster than I can rub 'em. That's why I ask knot-headed questions.
#210270 06/20/2006 4:16 AM
Most "Mustang II" front IFS's are just MII in style and design, not actually the light duty pieces from a MII. Get an aftermarket set-up built for your application and you should be fine,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#210271 06/21/2006 8:54 PM
I put a TCI M2 frontend in my 55 2nd,complete with power R&P steering.It really improved the driving and handling.Instalation is easy,if you follow the insructions.Make sure your measurements are correct before you weld the crossmember in.You will also need a dual master cylinder to accomodate the disc brakes.Prefferably a power unit.There are several companies selling these aftermarket M2 frontends.It aint cheap,but it sure makes a nice driving pickup.
#210272 06/21/2006 10:48 PM
Authorized Pest
Authorized Pest
Does this help? Bowtie-Max put an '82 Monte Carlo IFS into '55 1st Series Chevy pickup.
Peg
~ Peggy M
1949 Chevrolet 3804
#210273 06/21/2006 10:56 PM
There are several IFS frontends that can be adapted.A true Mustang 2,and Volarie just to name a couple.I went with the aftermarket,a little more expensive,but everything is new.No rebuilding the frontend.You will get all kinds of ideas here,look them over and take your pick.Good luck
