1 members (delky),
65
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 36 Junior Member | | Junior Member Joined: Apr 2005 Posts: 36 | My heat riser is stuck but I don't know what position it's stuck in. Would someone look at the picture here: http://home.hawaii.rr.com/calabash/hrv.JPG and tell me if it's open or closed. I'm hoping for open. Thanks, Rich | | | | | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | I would be curious also. Mine is stuck but am not sure in what position. I've tried everything I know to free it up and it looks like pulling the exhaust manifold would be neccessary. That ain't gonna happen soon. . . . | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If the flat surface on the bottom of the weight is horozontal it is closed. If it is at a 35-45 degree angle it is open. You often can free it up by applying penitrant & hammer it back & forth. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | use a torch and cut the butterfly out .weld up shaft holes.if it was stuck closed ,you would be burning up your valves in time
dan-pa
| | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Originally posted by dan-pa: weld up shaft holes. Wouldn't it be easier to fix it right? Mine was frozen solid. I kept workin' it with penatrant and tapping it with a small hammer. Now it works perfect and it does what it was meant to do. | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | Yes,but most of them are worn ,and leak giving you that sputter sound. Rich being from Hawaii and no winters.I would say no need for that.It just helps the engine warm up a little faster.Plus when removed no problem ever.Enjoy the sunshine,Happy truckin in your beautful state.  If you remove the manifold I sugest maybe putting a split manifold on. Man they sound pretty
dan-pa
| | | | | Joined: Jul 2005 Posts: 135 Member | | Member Joined: Jul 2005 Posts: 135 | May I suggest that you take the manifold off and clean it out from the inside.
Mine was stuck and the spring holder was broken so I did a switch with another I had.
The stuck one had considerable carbon build-up that was causing the seizing.
Setting the heat riser to rights made a world of difference in early start up driveablilty.
Word hard, play harder, enjoy life!
| | | | | Joined: Apr 2005 Posts: 36 Junior Member | | Junior Member Joined: Apr 2005 Posts: 36 | Thanks all. As dan-pa mentions, here in Hawaii I have absolutely no need for the function that the heat riser serves. If it is frozen in a position that is not doing any damage and not effecting the perfomance adversly, that is where I would want to keep it. Aloha, Rich | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | That one in the photo is in the open possition. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2005 Posts: 36 Junior Member | | Junior Member Joined: Apr 2005 Posts: 36 | Open to let exhaust flow out right? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Right. When it is closed it directs the exhaust up around the base of the carb. & then flows out. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | split manifold Go for it.duals exhust.bad to the bone.got a manifold setting on the hill side.Postage would cost much.So find another manifold and torch.Make a split manifold.If you want some kick *** ,put a 4 barrel on that 6 poper and it will come alive
dan-pa
| | | | | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | Hey Wrench-- open....closed...which way should it be before you start the engine?? I replaced my heat riser spring not too long ago. I put it on while it was closed (flat bottom of weight horizontal) but it never seems to open (flat bottom of weight at 35-45 degree angle) after the engine heats up.
should I re-install the heat riser spring with the valve open, so that when the engine warms to temp., the valve will close??
Chuck
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | NO! Normally they aren't adjustable, but it would be closed when cold, open after the engine warms up | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It opens when the engine is accelerated. The butterfly is off center so the pressure from the exhaust opens it. The hotter the spring gets the least tension & it opens sooner. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Back when crack was that place above a plumbers belt, we used solvent and a hammer to loosen heat risers. Rich even on a tropical island the heat riser should be allowed to heat the base of the carb until the engine warms up.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Apr 2006 Posts: 11 New Guy | | New Guy Joined: Apr 2006 Posts: 11 | I just noticed that the heat riser valve (HRV) spring on my 72 burb 292 is broken. Any place to get the spring or something close or the HRV? Searched the web no luck | | | | | Joined: Oct 2006 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 120 | I would not hammer it around. I did that and the weight moved on the axis so it was impossible to know how it was. Being stubborn I spent hours that ran into days on it and finally got a new manifold (used) with spring etc. It worked fine in winter. | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | A little penatrating oil and tap it left to right and so on until it comes loose. Don't try to tap the counter weight up and down you will break the pin which holds it in place and then you don't know what position it is in. A little paitence and persistance goes a long way and most times doesn't break anything in the process.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
