4 members (Wally / Montana, tclederman, Donf, cmayna), 91 guests, and 2 robots.
Topics128,086
Posts1,056,101
Members48,434
#209984 06/14/2006 7:59 PM
Apprentice
Apprentice
Looking to rebuild my front and rear suspension- stock. Any suggestions on manufactures? How is moog? Thanks Hans.
#209985 06/14/2006 8:08 PM
Socket Breaker
Socket Breaker
#209986 06/14/2006 9:17 PM
I used Moog on all my front end parts-made in USA, cost about 2x what the Chinese parts cost. but the quality is much better & I feel safer. I mean, a C10 lower ball joint cost $20 twenty years ago, how can one that cost $20 today be any good. If you compare the two parts the USA one is much heavier & a better quality metal. I don't try to save a buck on front end parts, brakes, or tires. brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#209987 06/14/2006 9:32 PM
MOOG is considered to be the best availible as far as front parts are concerned. We use them in our shop. Most of their parts have design improvements over the stock part. There is also availibity of most parts for Chevy/GMC to '49.
Bill Burmeister
#209988 06/15/2006 5:36 PM
Apprentice
Apprentice
Thank you for the response. Would you guys know if any one sells a complete kit for front and aft? Hans
#209989 06/15/2006 6:07 PM
LMC Truck sells front end kits for 66 C10s for about $150. I dunno what components they're using. They also sell rear suspension parts but the only kits I saw were for poly bushings and springs.
#209990 06/19/2006 5:23 AM
Moog is an OEM supplier to GM and others.
Jim
Good luck with your project!
#209991 06/19/2006 5:27 AM
I didn't see the year, but here is a link:http://www.suspension.com/g_m_trk_2wd.htm
Jim
