| | | Forums66 Topics128,084 Posts1,056,085 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 26 Apprentice | | Apprentice Joined: Dec 2005 Posts: 26 | Looking to rebuild my front and rear suspension- stock. Any suggestions on manufactures? How is moog? Thanks Hans. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I used Moog on all my front end parts-made in USA, cost about 2x what the Chinese parts cost. but the quality is much better & I feel safer. I mean, a C10 lower ball joint cost $20 twenty years ago, how can one that cost $20 today be any good. If you compare the two parts the USA one is much heavier & a better quality metal. I don't try to save a buck on front end parts, brakes, or tires. brian | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | MOOG is considered to be the best availible as far as front parts are concerned. We use them in our shop. Most of their parts have design improvements over the stock part. There is also availibity of most parts for Chevy/GMC to '49.
Bill Burmeister | | | | | Joined: Dec 2005 Posts: 26 Apprentice | | Apprentice Joined: Dec 2005 Posts: 26 | Thank you for the response. Would you guys know if any one sells a complete kit for front and aft? Hans | | | | | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | LMC Truck sells front end kits for 66 C10s for about $150. I dunno what components they're using. They also sell rear suspension parts but the only kits I saw were for poly bushings and springs. | | | | | Joined: Jun 2006 Posts: 110 Member | | Member Joined: Jun 2006 Posts: 110 | Moog is an OEM supplier to GM and others.
Jim
Good luck with your project!
| | | | | Joined: Jun 2006 Posts: 110 Member | | Member Joined: Jun 2006 Posts: 110 | I didn't see the year, but here is a link:http://www.suspension.com/g_m_trk_2wd.htm
Jim
