0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 2 Junior Member | | Junior Member Joined: Jun 2006 Posts: 2 | Hi guys,I just purchased a 57 chevy 1300(Canadian version of the 3100 so I m told).I did do some reading around the forum but still didn't find that "easy answer"if there even is. The truck is clean,was stripped down and san blasted,NO rust sweet deal. My question is what is the best donor chevy to use engine,tranny,rear end,front end.I have a connection in the salvage.Was thinking of getting a rolled dodge pick up with a HEMI but that just wouldn't be right. So best easy swap from a donor car/truck. I appreciate all your help. Thanks,Marc In Canada
57 pick up/90 celica GTS turbo swap
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Welcome to the Stovebolt "club".
Where did you get the idea that any of that stuff needs to be changed? | | | | | Joined: May 2006 Posts: 30 Junior Member | | Junior Member Joined: May 2006 Posts: 30 | Did it have a motor or tranny when you got it or was it long gone? | | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | My opinion is,you really have 3 ways to go and by your comment ,you've wittled it down to two options.You can either go stock or Gm modified. If you go stock, all you need to do is find the parts.The easiest modification is to go small block GM. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yeah, what'sa matter with original??  there is no "best", just what's your preference, or maybe "easiest" in a 57, which had the 265/283 optionally, any small block is an easy swap, and the original 3 speed bolts right up, or newer 3 speeds, like 68+ which have a syncro 1st - also the original or later OD 3 spd is a straight bolt in, and eliminates the "need" for "freeway gearing" in the rear - nothing wrong with the straight axle in front, and if you think you need better brakes there's easy ways to add front discs anything is possible, but study the situation and see if you really need to make a bunch of spendy changes to something that works fine as designed yes the CDN 1300 is the same as the US 3100, all the model designations were different, but the trucks were pretty much the same Bill | | | | | Joined: Jun 2006 Posts: 2 Junior Member | | Junior Member Joined: Jun 2006 Posts: 2 | Sorry,should of mentioned The original EVERYTHING is gone,I would stay stock if it would of been all there.The last owner pulled and it's long gone I just want to put it on the road,need it for computer/printer delivery.Celica too small. I might be complicating my life here,looking for easiest,quickest,cheapeast way to put engine and drivetrain/rad/brake booster.
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Since it sounds like you hauled it home in a box, here's my opinion:
I would say that dropping a Small Block (305 or even a 350) in would work fine, and be fairly easy, provided that it came with a V8. You can go with a variety of transmissions (e.g. SM420, T5, et cetera), but I'd stick with a Chevy rear from that time period. It'd just be easier to put in, and if you grab a 1/2 ton axle, you'll have the right sized brakes and everything!
If it came with an I6, then I'd go with a 235 or a 261, just because it'd be an easy swap and I'm lazy. You can use a variety of transmissions on these engines, too.
Since there IS no brake system or front axle, you'd need to find those, too. Again, I'd stick with a Chevy Setup from the same time period for ease of installation. If you're worried about stopping power, the drums work fine so long as you're not hotdogging -- which it sounds like you won't be. There are disc kits available, but if the donor truck doesn't have a hydrovac (or other brake booster) then it will be harder to brake with discs than with the original drums. | | |
