2 members (Lightholder's Dad, cmayna), 79 guests, and 6 robots.
Topics128,188
Posts1,057,215
Members48,465
I have a 1942 babbitt bearing 235 in my truck, Cloey and I'm wondering if I choose to use this truck very much, should replace the engine (maybe with a 260) or just use it as-is with the babbitt bearing 235. I don't want to wear-out or take a chance on ruining a perfectly good early engine if it has value as-is. The truck and engine only have 11,000 miles. What do you think?
I'd say if this motor is in good shape,good compression, not smoking, using oil or making weird noise, run it. But, I'd be looking for a 261 to replace it with when she is worn out. I'm running the same motor in my old coupe now has post 54 crank for full pressure oiling etc. But the snag with these older 235s is the head, very low compression and you can't just mill the thing.
Best of luck and very cool truck BTW.
1946 1/2-Ton Chevy
Ex Hall Monitor
Ex Hall Monitor
There's nothing wrong with a babbitted engine IF you don't over rev it. If you can stand driving that slowly grin I wouldn't change a thing.
I think he's asking the other question, guys. Is it of particular value?
I think the answer is NO.
Brian
It might be of some value to the owner of the truck that it came in if they want to make a museum piece out of the truck. If that's the case, don't drive it. OR put a newer 235 in there, drive it as much as you want and mothball the original 235 for future restoration and display.
24601
24601
Good advice, NM51!
By the way, I'm running the original babbitted 235 in my truck. So far, so good! I try not to over-rev it and I trailer the truck (GASP!!! SHOCK!!! HORROR*!!!!) if we're going long distances (i.e., anything beyond the DC Beltway)
* It gets worse -- I pull the trailer with a DODGE eek
grin
Oh yeah, and I own a FORD, too!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Thank you all for your good input on my babbitt engine. I'll drive it carefully, not over-rev and talk to it nicely!
Nice Truck.
Another quality post.
Real Trucks Rattle
jimerit
Did you do anything else to your 235 to run the later crank? Different oil pump? any oil passages need enlarged, resticted, blocked?? Do you need special main bearings?
Sorry Dale to hi-jack your thread. wink
Professional Novice
Dale,
where did that truck see service? It is a beauty!
1951 1 Ton Completed
Cloey was a fire tanker truck in service at a hunting camp in upper Michigan. The tank has since been removed and the truck repainted it's original red. She spent about 60 years garaged and maintained as a working tanker truck, and she put out a few fires as well.
The I'm not sure if, (like early Dodge power wagons) Chevys were also made for the civilian market; Cloey may be Military in origin, like a crash truck. The PTO still operates a pump under the rear of the bed.
