1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#209648 06/09/2006 2:12 PM
Junior Member
Junior Member
I received it yesterday from GM; surprisingly, it took onl 4 days to deliver. My question: the following "(RPO)" appears many times in vehicle and part descriptions...do any of you know what it references?
Jerboe
Fallbrook, Ca.
#209649 06/09/2006 2:26 PM
I
I Offline
Regular Production Option.
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
#209650 06/09/2006 2:30 PM
Junior Member
Junior Member
Thanks Inky05!
Jerboe
Fallbrook, Ca.
#209651 06/09/2006 2:48 PM
Jerbo,
Here are some definitions that might be helpful:
A regular production option is an option available from the factory (a "factory" installed option). Each RPO had a number ID.
A factory (or GM) accessory is an item sold by GM that could not be obtained installed at the factory but could be installed at the dealer (or, by the owner). Each GM accessory had a part number,
An aftermarket accessory is a non-GM item for your vehicle.
It is also possible that a dealer could have installed an item that was listed as a RPO but not ordered that way from the factory. In this case, the item was ordered by part number and installed by the dealer (or, by the owner).
Tim
