2 members (Bill Hanlon, 1 invisible),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 8 Junior Member | | Junior Member Joined: Jun 2006 Posts: 8 | I received it yesterday from GM; surprisingly, it took onl 4 days to deliver. My question: the following "(RPO)" appears many times in vehicle and part descriptions...do any of you know what it references?
Jerboe Fallbrook, Ca.
| | | | | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | Regular Production Option. | | | | | Joined: Jun 2006 Posts: 8 Junior Member | | Junior Member Joined: Jun 2006 Posts: 8 |
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Jerbo,
Here are some definitions that might be helpful:
A regular production option is an option available from the factory (a "factory" installed option). Each RPO had a number ID.
A factory (or GM) accessory is an item sold by GM that could not be obtained installed at the factory but could be installed at the dealer (or, by the owner). Each GM accessory had a part number,
An aftermarket accessory is a non-GM item for your vehicle.
It is also possible that a dealer could have installed an item that was listed as a RPO but not ordered that way from the factory. In this case, the item was ordered by part number and installed by the dealer (or, by the owner).
Tim | | |
