4 members (39Master85, Bill Hanlon, 2 invisible), 69 guests, and 4 robots.
Topics128,180
Posts1,057,150
Members48,464
#209203 06/07/2006 2:03 AM
Junior Member
Junior Member
I'm thinking about replaceing the wood in my 65.Would i be an idiot if I had the strips and sides of the bed Rhino-lined in a color to match the rest of the truck??? Has anyone tried this? I'm just kicking it around right now.
#209204 06/07/2006 2:51 AM
How about powder coating the strips to match your truck. Would probably be more durable in the long run. I've seen some pretty thick coatings my friend used on his frame, that stuff is bullet proof. The powder coater who did it mixed some colors and it came out super close to match.
1957 3805 Panel
It's not how you fall down, but how you get back up.
#209205 06/07/2006 3:09 AM
Rhino lining is fairly durable, but is kind of soft and rubbery. I'd go with line-x.
Make sure to get the UV additive, though, so the color stays right.
You could also use stainless steel strips and just have the bed sides lined. That is what I'm thinking about doing once I get a box back on mine.
