1 members (Ponchogl),
130
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | ok, will 3 clip hold the hubcap on, instead of 4? 49 3600, by the way. Just wondering if you guys have had any experience with it.... i don't want to lose a new $50 hubcap!  | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Your 3600 would be 8 lug, Id go with 4 clips. Im planning the same trick on some modern 8 lug rims don't know year or make, the big 3/4 ton caps fit in the hole but not tight fit, a little sloppy. How do yours fit in the new rims??? Thanks Jim This is for my 53 3600 stake bed. | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | Well, I'm using the old 8 lug, snap ring rims. I just bought new hubcaps, and surprisingly they fit well.... about the only parts i've bought that i'm happy with. | | |
