0 members (),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 103 | I have 2 6 volt horns mounted on my truck. One is the original - other is a Klaxon add on. Neither one is connected to a relay. One local fellow says that all old horns should have a relay between the battery and switch. Why so? | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | A relay should be used to carry the amps to the horn (or anything that draws high amps).You can use a lighter wire as your signal from the horn button to the relay.A Standard brand three terminal horn relay works well.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | If I use the the lighter wire on my relay, what should I use on my lighter? ;-) | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Stop light wire. Because you really shouldn't be lighting up anyway.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Hee,Hee very good.When I read R.Wyant's first line as 26 volt horns I thought he has some major voltage going to those horns.My horns are very horny!!
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Just be careful... Most FLAPS don't carry 6v relays. If you're running 12v, then don't sweat it.
12v relays DONT work on 6v systems.
6v relays can be VERY expensive. | | | | | Joined: Aug 2005 Posts: 107 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 107 | Can you guys clear this up for me, does the wire from the button go to the relay then the 2 horns also connect to the relay on independent tabs. I am about 80% done with the rewire on my 46 and this is one of the things I haven't finished. Thanks
1946 1/2 ton I'm not addicted I just don't know when to stop
