7 members (Hotrod Lincoln, DoubleB, Hanks custodian, Gdads51, HelmutVonSchet, KEVINSKI, 1 invisible), 81 guests, and 0 robots.
Topics128,081
Posts1,056,070
Members48,434
#208537 05/27/2006 12:52 AM
I have 2 6 volt horns mounted on my truck. One is the original - other is a Klaxon add on. Neither one is connected to a relay. One local fellow says that all old horns should have a relay between the battery and switch. Why so?
#208538 05/27/2006 1:09 AM
A relay should be used to carry the amps to the horn (or anything that draws high amps).You can use a lighter wire as your signal from the horn button to the relay.A Standard brand three terminal horn relay works well.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#208539 05/27/2006 3:42 AM
If I use the the lighter wire on my relay, what should I use on my lighter? ;-)
#208540 05/27/2006 3:48 AM
Stop light wire. Because you really shouldn't be lighting up anyway.
#208541 05/28/2006 3:09 PM
Hee,Hee very good.When I read R.Wyant's first line as 26 volt horns I thought he has some major voltage going to those horns.My horns are very horny!!
Wanted Good Woman:
#208542 05/29/2006 3:49 AM
Just be careful... Most FLAPS don't carry 6v relays. If you're running 12v, then don't sweat it.
12v relays DONT work on 6v systems.
6v relays can be VERY expensive.
#208543 05/31/2006 1:12 AM
Can you guys clear this up for me, does the wire from the button go to the relay then the 2 horns also connect to the relay on independent tabs. I am about 80% done with the rewire on my 46 and this is one of the things I haven't finished.
1946 1/2 ton
I'm not addicted I just don't know when to stop
