1 members (stoveboltgator), 218 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#208226 05/21/2006 8:15 PM
Apprentice
Apprentice
I'm building a 66 c10 shortbed fleet. I wanted to know if anyone knew the correct rim size and width, where there any optional rims available in 66. also, was power steering a option in 66 on the c-10. thank you much, Hans
#208227 05/22/2006 3:39 AM
Wheels were 6 lug 15x5.5.
Yes, Power steering was an option, but is pretty rare, I believe.
Mike Kelley
1966 Chevy C10 SWB - 250 L6/S10 T5
2002 Chevy Ext 1500 4x4
Http://myol66.wordpress.com
#208228 05/22/2006 5:41 AM
Apprentice
Apprentice
Thanks for the response Mike, I was starting to think this was a tough crowd. As far as you know was this the only option for the wheels? Hans
#208229 05/22/2006 1:06 PM
Hi Hans, I'm glad you got your answer. It's not a tough crowd, just when you get down to the details, they don't stick their neck out but wait till the right guy/year answers it. As you can see in the gallery the main bunch has a bit older vehicle. And not everybody visits here every day. Some live here,(like me) but some only step in once a week, if it takes too long, just answer your own message, with "bump" or some more info and you're on top of the pile again. If in need of answers and you can't wait, try emailing someone from the gallery with the same truck/year. That usually does the trick for me. While I'm at it, you're not in the Gallery yet? How come? grin
Have a good one,
Richard
#208230 05/22/2006 1:31 PM
Power steering is a very rare option. Of all the salvage yards or truck shows that I've been to, I have never seen an original power steering system. I don't have my owner's manual with me, but I think that there weren't any other wheel options.
Drew
#208231 05/22/2006 2:03 PM
web page
This is what I found on our Links page they might be able to help
Good Luck
Richard
#208232 05/22/2006 11:28 PM
Riding in the Passing Lane
I have seen 1 66 with power steering from the factory. It is the linkage type. The latter model is pretty easy to install.
1972 Chevy c10 Cheyenne Super
#208233 05/25/2006 9:32 PM
Apprentice
Apprentice
Thank you Drew and Richard for your help. Drew when you said you thought the P.S. system was a "linkage" type. What consist of a linkage type? Hans
#208234 05/25/2006 10:09 PM
The linkage system uses a hydraulic ram that is attached to the frame and the center link/tie rod to provide assist. It also had a spool valve in the center link/drag link to control the fluid flow. This system was used in cars up to '65, trucks to '66. Corvettes used it to the '82 models. The intigrated style would be a much better installation, not as many hoses to deal with.
Bill Burmeister
#208235 05/25/2006 10:21 PM
Socket Breaker
Socket Breaker
this company sells a good kit for putting power steering on these trucks, I ve read many good things about the product and their customer service:
REZ Engineering - No website yet, call or write - power steering kit. used trucks to part out(particularly 4x4). 1960 - 1966 Chevy/GMC. - PO Box 1584 - Great Falls, Montana 59405 - Ph. 406-727-9267
I have not used them myself.
-W
#208236 05/26/2006 3:55 AM
Wrenchbender Ret. and Longbox55 are correct on the power steering being linkage type and what it can be found on. The 77 Vette PS mounted very similar to the mounting points on the 65 project I sold, someone had already graped the vitals before I got it.
Woogeroo left out that the REZ kit mounts a 70 to 86 PS box to your frame. I had 63 a C20 with a 70 PS box. The previous owner made 1/2 inch spacers for the bolts that mount PS box. The setup worked great for me for 5 years. I have heard some negatives about mount the PS box that way. The kit or spacers are required because the later frames have a dimple for box. Yor biggiest problem maybe finding the brackets to mount the PS pump particularly if you have an L6.
Larry
I don't own a vehicle that isn't old enough to drink.
#208237 05/26/2006 4:30 AM
Apprentice
Apprentice
Thank you all for the info. Does any one have a good line on Stock rims in Northern california? 66 fleet swb. Hans
