| | | Forums66 Topics128,167 Posts1,057,017 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 58 Member | | Member Joined: Nov 2001 Posts: 58 | Yes! I know the question has been raised before, and yes, I did check the previous postings. However, I 've found a set of Cragar 17 x 8 eight lug rims that fit my 52 3/4 ton without interference or spacers. I was wondering who else out there in Stovebolt land is running 17" radials and if so what size tires are you running?
Bubba
| | | | | Joined: Nov 2000 Posts: 1,971 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,971 | I am really surprised that these wheels fit on the front of your truck without rubbing the tie rod ends. That's the trouble with modern wider, after-market or take-off rims - too much backspace (inset). Practically anything will fit on the rear. Have you measured the back of the wheel from the rim edge to the center of the wheel, where the wheel meets the drum? I would be interested in the model number of those wheels. Good luck.
Professional Novice
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I checked in the Michelin spec book and the only size that looks close would be 245/70/17E. It measures 9.5" wide by 30.6" tall and is the correct load rating for a 3/4 ton. Most of the 17" tires listed are for suvs and sport truck, not well suited for useage on a 3/4 ton. There is also a 265/70/17 listed,it may not clear the fender/drag link as it is taller and wider by 1".
Bill Burmeister | | | | | Joined: Nov 2001 Posts: 58 Member | | Member Joined: Nov 2001 Posts: 58 | Thanks Gents: I am absolutely sure the Cragar rim clears. I got them from Summit Racing. P/N is CRR 3978880[$56.95] for the rims and WVI-50080-1 for the chrome lug nuts. The rim has a 4.5 inch backspace. JimBo
Bubba
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 4.5" backspace shoul be fine. I'm running 15x8 Blazer rally wheels on my 3200 that have the same backspacing with no problems. I can easily fit my hand between the wheel and the tie rod. I also clear the drag link at full left lock with room to spare.
