7 members (Gdads51, Otto Skorzeny, TexasA&M48Truck, 5cameo8, TUTS 59, Youngin' Tut 59, Gray_Ghost),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,116 Posts1,056,599 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | 1952 one guy said there is two screws are they the ones under the door handle then he said lower down there was a nut is that on the lower door panel im going out tonight with a light to see if i can more but so far the doors have got me i cant see anything that comes lose did find another mouse nest help me please | | | | | Joined: Oct 2005 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 69 | 32fire2, I'm doing the doors on my 52 right now. There is two screws on the door handles & window cranks. One's a cap screw and there is another one under that. There is a nut on the front glass channel at the bottom, you can get to it from the access panel. There is alot of hiden screws so take your time and don't force things.
New deal for old steel
| | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | ok thanks Barney the ones on my 50 were eaisy ill just start uscrewing all i can find thanks so the cranks have to come out to get the window out or at least come loose | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | The handles must come off, then the cardboard panel behind it. From there, you can take all the screws off from around the metal "trim" piece and remove it. Then, take all the screws off from around the vent frame. After you remove the steel access panel from the lower portion of the door, you can use a 1/2 (I think) socket with and extension to remove the bolt holding the bottom of the vent frame (feel around for it, you'll find it). Pull the vent frame and vent window out together. Unscrew the actual window crank mechanism from the door and remove. The window will then fall to halfway down the door and hit a rubber 'undecayed' bumpstop. Lift out the glass. No problem
Colin | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | wow thanks will give it a go tomorrow thanks for all the help | | | | | Joined: Sep 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 310 | Ok, we waited long enough now, not that we have any advice,but DID YOU GET IT OUT ? . Don't leave us here without a word please. | | | | | Joined: Jan 2006 Posts: 43 Member | | Member Joined: Jan 2006 Posts: 43 | while were on door panels i have a question.the cardboard panels i bought do not fit flush it seems the door latch is pushing it out the latch seems its upside down but thats the only way it works. it seems like the flat bar from the handle to the latch would go in the indention of the door but i cant figure it out pictures or directions will help thanks the kid | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | went down to the shop have a wing window in a bucket now i see the bolts are under the window trim which is still on the door so when i take the trim off i see how the window comes out so yes its as good as done now thanks for all the help | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | on my 53 pickup there are sponge spacers that hold the cardboard away from the remote pull rod.See "side door instruction index Sect 1 sheet 1.05" of the 1947-1954 truck Factory Assembly manual | | |
