1 members (Donf), 102 guests, and 3 robots.
Topics128,026
Posts1,055,405
Members48,422
#207692 05/13/2006 4:24 AM
I have a 3.07 ring and pinion gears and was considering swapping those with the 3.73 that I have now to increase gas mileage. I have a 250 and a column shift 3-spd. I was wondering if going to a 3.07 would bog the engine down too much while crusing? I know that 3.07 was offered as an option from Chevy. Also, is it easier to do the work myself, or to have a shop do it for me? From the looks of the 1963 Shop Manual and Supplement, it doesn't look to be that hard of a job to do. Thanks for your help.
Drew
'66 C-10 stepside
#207693 05/13/2006 12:55 PM
Instalation is not much of a problem but read up on setting the backlash. has to be perfect.
#207694 05/13/2006 7:15 PM
3.07 gears would get you better gas mileage than a 3.73...
Just sayin'.
#207695 05/13/2006 7:26 PM
you are shooting in the dark here..1st if your 3.0 gears are used you will most likely have a noisey diff..2 the setting and preloads are not that easy...3 if you go over the top on gearing you will lose preformance and fuel milage...with a 250 look at a 3.55 doc
#207696 05/13/2006 9:24 PM
Riding in the Passing Lane
I think Doc is right unless you have very small dia. tires. That rear end is a lot harder to set up than the 62 on back. The side bearings do not have screw adjustments. You have to juggle shims to get it right.
1972 Chevy c10 Cheyenne Super
#207697 05/14/2006 2:10 AM
Thanks guys. Wrenchbender, I'm currently running 235/75-R15 tires in all four corners.
Drew
'66 C-10 stepside
#207698 05/14/2006 3:05 PM
I don,t think it would drive good with 3:07. Like Doc posted, 3:55 or keep the 3:73 & add o-drive.
#207699 05/14/2006 11:46 PM
I think the 3.7 should do you nicely for what you would gain changing,,if you have fuel problem try to correct it first...doc
#207700 05/15/2006 3:26 AM
I can't speak to how hard the swap would be, I just don't know. But I'm running similar size tires, a 3.08 geared rear, an SM420 and a GMC 270.
This is in my '55 1st Suburban and as long as I don't put a trailer behind it I think it drives fine. I get 14 running around town and maybe 17 on the highway.
