0 members (),
40
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20755 09/11/2003 3:03 AM | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Hi Gang, Saturday night while under the truck I accidently brushed my hand against the exhaust pipe, and the whole exhaust pipe wobbled from the manifold all the way to the left rear taillight. :o Any suggestions on how to tighten the exhaust pipe to the manifold without snapping off one of the bolts? TIA, David
My truck don't leak oil, it just marks its teritory.
#20756 09/11/2003 4:30 AM | Joined: Dec 2001 Posts: 31 Member | | Member Joined: Dec 2001 Posts: 31 | It would seem to me that the doughnut gasket at the flange has disintagrated and needs to be replaced. Seems to happen often on mine. Good luck!
Thomas Mott 1949 GMC 250 1957 Dodge COE c-700 1959 Chris Craft 17' w/big journal 327 for more power
#20757 09/11/2003 4:52 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What engine do you have (size and year).
The 1962 235/261 exhaust pipe does not use a doughnut gasket (although I think one could be used).
You are right that the nuts holding the exhaust pipe to the manifold are often hard to deal with. One way or another you will have to tighen the connection (no matter what gasket you have).
Good luck, Tim | | |
#20758 09/11/2003 7:01 PM | Joined: Mar 2003 Posts: 17 Member | | Member Joined: Mar 2003 Posts: 17 | | | |
#20759 09/11/2003 11:07 PM | Joined: Oct 2001 Posts: 39 Member | | Member Joined: Oct 2001 Posts: 39 | Doughnut gasket? What! I had to use some old compooter cable yesterday going home from work because my pipe was draggin. Thats the way I fixes it, sounds tacky but kept it from draggin.
BIGGY
1965 CHEVY "BIG RED"
