| | | Forums66 Topics128,088 Posts1,056,113 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | I'm looking for a gas tank for my 39 chevy truck. Am I correct in assuming that the 41-46 chevy/GM tanks will also fit? There I go assuming again!
Thanks, | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I believe that they will -- the cabs are the same -- but I'm not 100% sure. They may have changed the mounts and the seat.
I can measure my tank when I get home tonight and let you know. | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Donf, the tanks for the 37-46 1/2 tons were the same 15 gal. there was also a 18 gal tank available.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Tank itself is the same, but the outlet comes out in a different spot. One comes out in the center of the tank, and the other comes out more to one side. Can't remember which is which without looking. Nothing a small holesaw can't fix. | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | Donf, instead of replacing the original, why dont you mount one under the bed? out of the cab.
I'll be pulling my gas tank out of my 39 in the "future", you can have it if you want to pay the shipping charges. I dont know what kind of shape it is tho, as i've not looked under it.
| | | | | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | Rusty Rod,
The reason for not relocating the tank is that I’m trying to keep my 39 as stock as possible. Given its current condition, that should be some task. Currently, I'm using a boat gas tank.
I appreciate your generous offer of the tank and will certainly take you up on it. You can see from my site that I have a way to go so time is not of the essence. http://wrangler.nmsu.edu/~donf/
Took a look at your site. Great looking 39 you put together.
Thanks, | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | Wow... you sure have your work cut out for you with that 39...
