6 members (Greg '46, Hotrod Lincoln, Phak1, Otto Skorzeny, 2 invisible), 234 guests, and 2 robots.
Topics128,080
Posts1,056,063
Members48,433
#207536 05/10/2006 3:15 PM
I'm looking for a gas tank for my 39 chevy truck. Am I correct in assuming that the 41-46 chevy/GM tanks will also fit? There I go assuming again!
#207537 05/10/2006 4:01 PM
I believe that they will -- the cabs are the same -- but I'm not 100% sure. They may have changed the mounts and the seat.
I can measure my tank when I get home tonight and let you know.
#207538 05/10/2006 10:23 PM
Donf, the tanks for the 37-46 1/2 tons were the same 15 gal. there was also a 18 gal tank available.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#207539 05/11/2006 12:43 AM
Tank itself is the same, but the outlet comes out in a different spot. One comes out in the center of the tank, and the other comes out more to one side. Can't remember which is which without looking. Nothing a small holesaw can't fix.
To be long remembered as he's cruising in
The Passing Lane
#207540 05/11/2006 5:18 PM
Donf, instead of replacing the original, why dont you mount one under the bed? out of the cab.
I'll be pulling my gas tank out of my 39 in the "future", you can have it if you want to pay the shipping charges. I dont know what kind of shape it is tho, as i've not looked under it.
Another quality post.
Real Trucks Rattle
#207541 05/12/2006 3:08 PM
Rusty Rod,
The reason for not relocating the tank is that I’m trying to keep my 39 as stock as possible. Given its current condition, that should be some task. Currently, I'm using a boat gas tank.
I appreciate your generous offer of the tank and will certainly take you up on it. You can see from my site that I have a way to go so time is not of the essence. http://wrangler.nmsu.edu/~donf/
Took a look at your site. Great looking 39 you put together.
#207542 05/13/2006 5:18 PM
Wow... you sure have your work cut out for you with that 39...
Real Trucks Rattle
