1 members (Rnl364), 104 guests, and 6 robots.
Topics128,077
Posts1,056,033
Members48,433
#207455 05/09/2006 6:34 AM
I'm installing a rebuilt 3 speed Saginaw to go with my rebuilt 292. I went the whole 9 yards, new pressure plate clutch throw out bearing pilot bushing. Used the alignment tool,triple checked made sure everything lined up. Now time to slide er in. It stopped 1" from the bell housing and wont go further. Tried a little high temp grease on the splines Nada. I've never run in to this problem before. All the trannys I put in will go in ok with a little effort.
#207456 05/09/2006 7:16 AM
Sounds like it's not going in to the pilot bushing. Did you test fit it on the input shaft? Maybe you put a bur in it when you put it in
#207457 05/09/2006 9:53 AM
I had the same situation with that lousy plastic alignment tool that came with the new clutch kit.
Used an old inputshaft for alignment and it slipped right in.
Frank
#207458 05/09/2006 10:17 AM
Big T and Stovebold are right. Call around to some local mechanics or maybe even the Chevy dealership and see if you can borrow an old input shaft. The plastic alighnment tools often are just wishful thinking.
#207459 05/09/2006 11:10 AM
depress the cluth lever it should slide in with the pedle on the floor
#207460 05/09/2006 4:40 PM
You should make sure the input shaft fits into the pilot bearing, that will hold it out about an inch. Also depressing the clutch pedal will release the disc so it will move enough to align if it's not just right. Good luck, it should work now.
#207461 05/10/2006 6:04 PM
Thanks guys for your help. I found an old 3 speed tranny I had behind the garage. I tore it down and got the input shaft. I'll never use that cheap plastic alignment tool again! Also Depressing the clutch pedal made the tranny glide right in!
#207462 05/10/2006 6:28 PM
Wow, you were REALLY grateful. Congrats on the install.
#207463 05/10/2006 10:03 PM
Quote
Does that make it a 3-speed PowerGlide? :p
