2 members (1955 1 Series, Hotrod Lincoln), 148 guests, and 2 robots.
Topics128,189
Posts1,057,337
Members48,469
#20737 05/19/2004 3:54 AM
I'm going to use one of the HEI distributors from Langdon's on my engine rebuild. The recommended advance is somewhere around 20 degrees. The shop manual for the 235/261 says to use a timing light and get the flywheel ball to show up at the right time, but I'm thinking that is for a 5 degree advance.
How does one go about setting at 20 degrees for initial setup? Once I get it close enough to run I can just use one of those fancy timing lights to get exact.
Thanks in advance.
shoeless
#20738 05/19/2004 8:10 AM
if you have a mark that's 5 degrees, and a TDC mark, then 20 degrees would be back another 3 spaces of the distance from TDC to 5 BTDC, i.e. 4 5 degree intervals would be about 20....
to me this sounds like a WHOLE LOT of advance. My supercharged lincon only got like 12 degrees, but hey, what do I know, it could be a difference in how the distb is set up and how it delivers spark.
#20739 05/19/2004 3:58 PM
It sounds like he's talking total advance, which is the combined vacuum and mechanical at speed. I know how to set it with a degreed balancer and the correct timing light, but not on an engine without those luxuries.
Call Tom and be sure, he'll shoot straight with you.
Fred
52 3600
69 C-10
