Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 172 guests, and 1 robot.
Topics128,274
Posts1,058,433
Members48,490
#207239 05/07/2006 6:08 PM
Any ideas on under bed gas tanks for a 46 1/2 ton? Its kinda scary having the gas tank in the cab.
#207240 05/07/2006 8:02 PM
This topic has been discussed several times before.
It can be done, and so long as the tank stays between the frame rails, it's generally safe enough. However: It is just as safe with you in the cab. just don't mount it behind the differential or get saddle tanks. That's just asking for badness.
If I recall correctly, all of the various threads were in this forum and in the engine and driveline shop.
