1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | The renewed unrusted body parts will be coming back from the body and paint guy soon. Would like to go down to the hardware store and buy all the necessary bolts, nuts and washers needed (in Stainless) to put the Rattletrap back together. Has anyone made a list of the necessary hardware for this feat? Not clutchhead, just standard SAE. Thanks ahead of time, -jeff | | | | | Joined: May 2002 Posts: 144 Shop Shark | | Shop Shark Joined: May 2002 Posts: 144 | Rattletrap: In my area the hardware stores have "made in China" bolts that are barely strong enough for woodwork and certainly not not for vehicles. I am not conversant with the terminology for the strength of bolts but I do know there is one. All bolts are not created equally! Ter | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I bought a kit from one of the vendors, Jim Carter mabye? It had all the bolts to assemble the cab and front end. Each set of bolts was in a separate plastic bag with a label, which made it easy to figure out which one went where. I think it was about $70, which I think is a good price considering how much I would have paid buying the bolts, washers and nuts individually at a hardware store.
| | | | | Joined: Feb 2011 Posts: 42 New Guy | | New Guy Joined: Feb 2011 Posts: 42 | You definitely want at least grade 8 hardware. They should be yellow brass in color, with I think 5 tick marks on the head. Try and find a specialty hardware store in your area that sells the full fastener specturm. At home in Dallas there's a huge hardware store that has an entire aisle dedicated to just hi strength hardware. At a place like that, you could easily get everything you need for under $70. As for an itemized list of everything you need, you might pick up a factory assembly manual, or call our site sponsor or another one of the vendors to see whats included in one of their kits.
-Matt | | |
