0 members (),
41
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | I think I've heard something about a "heavy 1/2-ton" option on early '60s trucks, where the 1/2-ton trucks were given heavier duty suspension bits. I'm wondering, because I've got a '62 Suburban 1/2-ton that was originally ordered by the California Parks and Services division, with 283/4spd granny tranny. It seems like it would be the PERFECT candidate to come with a stiffer, more rugged suspension. Why I'm wondering, specifically, is because the rear springs, even after all these years, are very stiff. The torsion bars take rail road crossings and the like very nicely...the rear suspension jars your teeth lose. I'm wondering if this could be because the rear has stiffer springs from the factory. Throwing more into the matter, it has a later (non-adjust brakes) Dana 44 under it, that was a bolt in. I'm thinking perhaps if this truck originally came with 3/4-ton springs, the pinion angle might have been different, which might explain the highway speed vibration I have.
Any info on a "heavy Half-ton" option would be greatly appreciated. -Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I know with the Fiourduh's, the half ton was an F-100. The heavy half would be a F-150.
My 59 GMC is a 100. They have 150's on up. I would "assume" that the 150 would be a heavy half.
Help me out guys.
Chevy has 3100 which is half/shortbox, and 3200 which are half/longbox. A 3400 is 3/4. | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | In the 50's, and before, the GMC 150 was the 3/4 ton designation. I don't remember any heavy half tons until the mid-70's and that was in response to the unleaded gas requirements for vehicles under 6000 GVW circa 1975. By then Chevies were C/K10, C/K20, etc. and half ton GMC's were already 1500's. 3/4-ton Jimmy 2500's. That's about the time Ford came out with the F-150 and had both half tons for awhile. One correction Builder: Chevy 3/4 tons were 3600, not 3400. Brad, as to your heavy duty 62 'burb: anything is possible, especially with a government purchase.
Professional Novice
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Thanks Frank50. I see my error. | | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | The 1954 shop manual specifies the heavy 1/2 ton has 10-leaf rear springs. The standard 1/2 uses 7 or 8 leaf springs.
My 1-ton 1950 GMC has rear overload springs mounted above the regular springs and I'll bet they were an option for 1/2 ton trucks too.
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | My '50 half ton has overload springs on it too, over the axle, with rubber bumpers to contact the frame. They look stock. The rest of the truck has the stock parts. It does seem to work like a heavy half, although the overloads don't kick in until the regular springs drop enough so they hit the frame.
The reason your springs are really stiff is that they have rusted together. If you take them apart, clean up the surfaces so they slide smoothly, grind off any ridges, and replace and grease the bushings, the ride should soften up quite a bit.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | My rear springs are coils--that's why I was wondering if maybe they were taller/stiffer than regular '62 springs. I'm just constantly surprised by how harsh the rear suspension is when going over bumps. Granted, it's empty, but all that Suburban sheetmetal, rear doors and glass isn't light. This past weekend, I hauled a pair of Mopar brake drums, backing plates, 6-leaf '57 Chevy station wagon springs, axle shafts (heavy duty), a Mopar 8 3/4 center section, and the complete stock rear end out of my '57 Chevy, complete with 5-leaf springs, traction bars, drums, axles and center section. So there was several hundred pounds--probably around 600 or so. And the ride wasn't exactly harsh anymore, but it wasn't sagging-springs soft either. -Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Jan 2006 Posts: 21 Junior Member | | Junior Member Joined: Jan 2006 Posts: 21 | I had a chevy 71 with a heavy half rear end---9' bed--coil springs--made to haul a camper. Don't know how far back thehose could be ordered.
Taco
