3 members (Otto Skorzeny, dunfire, Rusty Heaps), 91 guests, and 1 robot.
Topics128,050
Posts1,055,644
#206574 04/24/2006 12:42 AM
Z
ZB3
Offline
Z Offline
Hey, I finally was able to remove the steering wheel and now I need to remove the column so I can remove the cab. 1952 1/2 ton. Two questions: 1) What is the best way to remove the steering column? 2) there is a metal/rubber seal around the column that will not slip over the horn wire. What do I do? Thanks in advance, Wayne
#206575 04/24/2006 2:13 AM
3B Offline
Hy ZB3, disconnect the horn wire at it's connection near the column, push the wire into the column [you can fish it back out later]. Two bolts near the top of the column secure it to the dash, the metal/rubber plate you described can be slid up and off while your pulling the column out the bottom of the truck. But first you must remove the pitman arm [the piece that connects the steering box to the steering linkage] and the four? bolts that secure the steering box to the frame. You should jack the truck up quite a bit in the front to make it easier to get the box out from under the truck. I hope that helps.
#206576 04/24/2006 8:25 PM
Z
ZB3
Offline
Z Offline
What is the best way to remove the pitman arm from the steering box? It looks like the arm is over some splines. Is there a special puller? Thanks, Wayne
#206577 04/24/2006 9:10 PM
yes there's a puller designed for the job - usually available from tool rental places
#206578 04/25/2006 4:31 AM
If you have sometype of hoist available,you
dont have to take the steering box off,you can lift the cab up and pull the frame out from
under,I have done this on 3 trucks. I can send you
pictures if you are interested
#206579 04/25/2006 10:50 PM
I guess with the proper lift, taking the cab off the column is ok, probably need to be a good aim to get it back first try!
But if you plan on removing the box and column from the frame rail, their are 5 bolts, not 4. The last is underneath, caked in gook more than likely.
#206580 04/25/2006 11:15 PM
Z
ZB3
Offline
Z Offline
Someone said that I can use a pickle fork to remove the pitman arm instead of a puller. Is that true? Thanks for all of the responses. This truck is great stress release! Have a terrific day, Wayne
#206581 04/25/2006 11:41 PM
Just undo the drag link. You can remove the box/column without taking the pitman arm off. As Brian mentioned make sure you find that last bolt on the inside of the frame rail.
Curt B.
You Tube
#206582 04/26/2006 4:06 PM
zb3. no you dont wanna use a pickle fork if you do remove the pitman arm. you need a pitman arm remover. i bought a suffecient one for $15 at autozone. they will rent one to you as well.
http://www.eastwoodco.com/shopping/...p;RS=1&itemID=2456&keyword=49033
