| | | Forums66 Topics128,159 Posts1,057,029 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | Got a question from Bob W -- I have installed a Klaxon horn (AAOGAH type)-- it has the same sound as a "Dive - Dive" sub horn used in WWII. I want to know anything about this horn - Google results are very fuzzy. I do know it is a Klaxon 20L horn. That is all I know. It is not original to Chevy trucks, but I have it mounted / working. You can hear it for miles in the WV "hollers".
Thanks, Bob W.
~ One of many.
| | | | | Joined: Apr 2005 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 196 | Bob,
I put one in my 66 and I can't seem to drive it anywhere without tooting it at least once. Mine's one of the newer ones you can get at most local auto parts stores, not the old ones like yours. Have fun with it.
Rance
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding) I'm too sexy for my hair, that's why it isn't there
| | | | | Joined: Jun 2004 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 103 | Smoe more info on the horn: Manufactured by Lovell-McConnel / Patent date 1908 Newark, NJ I am guessing it was for early 1900 cars. It is six volt and very heavy. Any horn experts out there? Thanks, Bob W. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | http://vccachat.org/cgi-bin/ultimatebb.cgi I'm amazed at the knowledge these folks have.
| | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | i had one of those that mounted uder the floor with a foot powered plunger. from some old ford i think. i wonder if electric ones were ever stock. they were pop in the 50s and early 60s.
"It ain't a truck if you can't hose out the cab."
| | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I have a modern one as well, I think people expect you to have one, especially when you get the blow the horn signal.
Does anyone know if the klaxon was even put on Chevys? I have an original but I think it came off a Ford.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Maybe on 1931 and earlier Chevies. | | |
