0 members (),
138
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20623 02/12/2004 2:19 AM | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | Everyone knows what I'm talking about. It's that retangular thing which is welded onto the bottomside of the tube way up front near the ujoint. Is it for 3/4 ton application? Though I have never used it I'm just wondering.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#20624 02/12/2004 4:12 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | That is where the "E" brake return spring ataches
See the USA in your vintage Chevrolet! My Blog | | |
#20625 02/12/2004 4:45 AM | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | No, No, No,....I don't think so... The direction of the E brake rod is way over to the drivers side of the truck. Having the spring attach to the torque tube "maka no sensa". It must be related to another tonnage instead of 1/2 ton.
Geez, maybe I need to take a picture of what I'm talkin about?
#20626 02/12/2004 5:23 AM | Joined: Nov 2003 Posts: 53 Member | | Member Joined: Nov 2003 Posts: 53 | Years ago, I remember an old mechanic talking about a "ballast" that was welded to the torque tube to upset the resonance of the tube. Without it, the tube 'sings' at certain speeds. Could that be what he was referring to? | | |
#20627 02/12/2004 5:26 AM | Joined: Jul 2003 Posts: 141 Member | | Member Joined: Jul 2003 Posts: 141 | I have wondered about that bracket also. The parking brake return spring on my '52 does NOT attach at that point. Perhaps it was designed by an engineer who wanted restorers 50 years later to ask "what the heck was this for?".
It also may have been used as an attachment point during factory assembly. | | |
#20628 02/12/2004 5:27 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I saw that square peg but am still looking for the round hole...
54 3100 with 235 62 flatbed dump C60 with 261
#20629 02/12/2004 5:30 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Craig - shoot us a picture, please!
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#20630 02/12/2004 7:53 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Come to think of it, it is only on passenger cars that the spring is attached to that spot. I'm not sure why they put it on trucks?
#20631 02/12/2004 1:58 PM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | I know what you are talking about, but do not know the purpose. I thought it might be positioned to protect the end of the torque tube from hitting the ground when not attached to the tranny, but it does not do that. Perhaps its only function is like your belly button now - to collect dirt! | | |
#20633 02/12/2004 3:19 PM | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | Tim, I have a 49 1/2 ton and my E brake rod does not have the tab as pictured in the assembly manual that you posted. I have the spring attached to the crossmember but don't know where it attaches to the activator rod. Any ideas? | | |
#20634 02/12/2004 3:43 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Its the E-brake return spring on sedans. My '54 uses the big spring between there and the "pull bar" that attaches to the two parking brake cables. A rod from my E-brake handle (not a pedal as shown) pulls on the "pull bar" to engage brake. Then the return spring anchored on torque tube returns the "pull bar" to its disengaged position.
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#20635 02/12/2004 3:54 PM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Rwise: The parking brake control rod is made up of two pieces, with a joint between them. The spring connects to that joint. If it does not reach that far, it is because you do not have the extension needed from the spring to the joint. It is just a heavy piece of wire with hooks on the ends. If you need it's exact length, let me know and I will measure the one on my 49. | | |
#20636 02/12/2004 4:32 PM | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | Brian, Thanks, I do not have the wire extension and would appreciate a measurement in case I have to make one. Thanks again. | | |
#20637 02/12/2004 4:38 PM | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | Look just right of the chain on the torque tube and you'll all see what I'm yakin' about. http://community.webshots.com/photo/111968325/111971596ZnsMWQ
#20638 02/12/2004 4:49 PM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | That wire is 9 inches, top of loop to top of loop. It looks the diameter of coat hanger wire, but those loops have to be pretty strong, to not be straightened by the spring tension. | | |
#20639 02/15/2004 5:51 AM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | cmayna That spot that your are refering to is the Johnson Rod factory allignment boss. Once the Johnson Rod had been installed at the factory the next step was to allign it to the truck.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#20640 02/15/2004 6:37 AM | Joined: Aug 2001 Posts: 139 Member | | Member Joined: Aug 2001 Posts: 139 | cmayna, I think you are talking about the weight they use to balence the touque tube. Mike  | | |
#20641 02/15/2004 3:59 PM | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 |
#20642 02/15/2004 7:07 PM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Craig Please don't encourage him. (it was a joke) | | |
#20643 02/16/2004 3:28 PM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Slomoe that's just silly. cmayna if you go to the FAQ section there is a write up on how to adjust your Johnson Rod. Of course this is how to do it a home, the factory had specialized equiptment for this proceedure.
#20644 02/16/2004 3:36 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | My Johnson rod is the only part rusted solid on my truck. I guess they never used it.
#20645 02/16/2004 7:47 PM | Joined: Oct 2001 Posts: 54 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 54 | GM ENGINEERS PUT THAT THERE TO SNAG ON YOUR COAT OR JACKET WHEN YOU ROLL UNDER YOUR TRUCK. IN OTHER WORDS - I HAVE NO CLUE. GOOD QUESTION I MUST SAY.
Yes, officer it's licensed.
#20646 02/17/2004 6:54 AM | Joined: Mar 2000 Posts: 1,184 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,184 | I looked in my factory shop manual and my factory assembly manual. Then I looked at my '48 1/2 ton. It is most definitely not where the e-brake spring attached. The e-brake spring is attached to a crossmember closer to the rear end and then to a tab on the e-brake rod that goes to the rear, and that agrees with the factory assembly manual.
Then I went out and looked at my torque tube. I have the same piece on mine, and it's obvious that nothing was attached to it (no wear marks or signs of something attached.) I don't know what it's there for, but it's definitely *not* for balancing the driveshaft because the outside of the torque tube never turned. The driveshaft was inside the outer tube, so putting "weights" on the outside housing would accomplish nothing.
I'll ask my friend Wally if he knows what it was there for. My best guess is a jack point. If you removed the torque tube assembly (which would include the rear end, driveshaft and both wheels), you could rest the front of the assembly on that point with a jackstand that had a pin in it that would fit through the slot and keep it from rolling off the jackstand. | | |
#20647 02/18/2004 12:42 AM | Joined: Mar 2000 Posts: 1,184 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,184 | I spoke to my friend Wally today, and he told me that the square piece with the slot was used as a mounting point for "radius rods". These rods were mounted from that point to a mounting point on each side of the rear axle (forming a triangle between the raidus rod, the torque tube and one side of the rear axle) and were used to keep the rear axle from "walking". He said they were used on one ton and bigger trucks as well as powered farm wagons and other heavier equipment.
I asked him why they would be on a 1/2 ton truck's torque tube, and said that they were on all torque tubes because then the tubes were manufactured they never knew what vehicle they would be used in.
I told him what my best guess was (a place for a jack with a pin) and he said that they were sometimes used that way because they were convenient. | | |
#20648 02/18/2004 1:03 AM | | Anonymous Unregistered | | Anonymous Unregistered | hmmmm . . . 1 ton and bigger trucks always had open drivelines.
If the torque tubes could be used on any number of vehicles and they were shared with cars and cars used the point as a e-brake return spring anchor . . . that might explain it. | | |
#20649 02/18/2004 4:45 AM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | In all seriousness I would guess that it was used as some sort of aid in the build process of the driveline. But hey that is just my guess.
#20650 02/18/2004 5:36 AM | Joined: Mar 2000 Posts: 1,184 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,184 | Ken, the big trucks (1 ton and up) still had the torque tubes until 1941. | | |
