4 members (Simon1954, klhansen, Joe H, baldeagle), 82 guests, and 11 robots.
Topics128,019
Posts1,055,343
Members48,419
#206086 04/17/2006 2:10 AM
yea so the wipers on my truck suck. the guy i bought the truck from threw in some "new ones" but they arent worth crap. i think it might just be the arms that hold the wipers on. they basically just skim over most of the water on the windshield or spread and smear it across the rest of the windshield. any ideas? thanks in advance.
patrick
#206087 04/17/2006 4:16 PM
The springs in your arms must be too weak to force the rubber onto the glass.
Mike Barnes
1950 GMC 1-ton pickup
#206088 04/17/2006 7:11 PM
yea thats what im thinkin. ill probably just invest in a whole new wiper system. btw is there supposed to be a switch for the washer fluid or did they not have washer fluid back in the day?
#206089 04/17/2006 7:17 PM
Hi-jcking a thread again, but one of the things that doesn't wprk on my '66 is the washer pump.
There is a plunger built into the wiper switch, but it doesn't appear to do anything. The washer motor appears to be fitted to the lower rear of the wipesr motoe (under the dash).
Is it supposed to be the pump up type? I might just bin it in favour of a electic one.
#206090 04/17/2006 10:46 PM
Former Workshop Owner
The '63 that I owned many years ago did not have a washer sprayer. If it was available, it most likely would have been an option.
If I remember correctly, the windshield on a '63 is the wrap around type, and would probably require a very flexible wiper arm to wipe effectively. It could be possible that someone replaced the arms years ago with arms that do not match the windshield well.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
#206091 04/17/2006 10:57 PM
well the wipers only go across the front of the windshield which is fine but they dont get the water off effectively enough. im pretty sure the springs just arent strong enough on the arms and i think the wiper blades i just put on mustve been sitting around for a while when the previous owner had them becuase they dont seem new but maybe when i install new arms theyll work better. thanks everyone.
