5 members (Gdads51, SmalltownTRKGuy, 52Carl, Cosmo, 55shaker), 62 guests, and 0 robots.
Topics128,049
Posts1,055,629
#20600 05/05/2005 6:16 AM
Junior Member
Junior Member
Does anyone have a source for performance parts for a 235???? P.A.W. used to carry a few parts for these old engines but thier new catalog leaves a lot to be desired in the non V8 category. I know these engines were used in several types of racing once upon a time so there HAS to be a source somewhere! Help me stovebolters you're my only hope!
#20601 05/05/2005 7:47 AM
#20602 05/05/2005 9:32 AM
Any cam grinder can fix you up if you have a core and know what you want.Try Delta Cams,do a Google search,nearby you somewhere,they have many grinds available ,in fact I believe they grind cams for Patrick's. I personally used them once and another is Colt Cams in BC Canada,great workmanship.By the way,a good reground cam only costs about 70 bucks.
#20603 05/05/2005 11:15 AM
Try www.egge.com
If your rich do a search for wayne manufacturing.
They offer several high dollar bolt ons including 12 port heads. They also offer several types of cams and valve train set-ups. I ordered the catalog and nearly fell over when I saw the prices. These guys know what they are doing... check out some of there records at the salt flats.
#20604 05/05/2005 11:19 AM
The Wayne Mfg. Co. or Arias machine specialist website is http://www.waynemfgco.com
#20605 05/05/2005 12:49 PM
I got mine from Howards cams and am happy with it. It's got a little rumpy idle and seems to build good power. Also for other hop up parts Langdons has some good stuff for these engines. Happy hunting.
#20606 05/05/2005 1:18 PM
8
8 Offline
Another alternative is to run a 261 cam. Higher lift and longer duration than the 235 cam, but keeps the torque in the usable RPM range. I put one in my new 235 and it runs quite nicely. No rump in the idle, though. frown Oh, and I've never quite known why, but I've always been told not to run a reground cam. I guess one reason would be cost. About $70 for reground, or about $110 for new (what I paid for mine). For that difference I'll go new every time.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
