0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#205915 04/14/2006 5:56 PM
53 Chevy 1/2 ton ---I need to replace the flexible hose that connects the fitting on the bottom of the gas tank to the fuel line. It was leaking from a crack in the hose. The petcock seems to tighten down OK to cut off the fuel from the tank , but my question is: how much fuel can I expect to run out of the line when I disconnect the hose? Will it just be whatever is in the fuel line up as far as the fuel pump, or will gravity drain the line all the way to the in-line fuel filter and the carb?
#205916 04/14/2006 8:27 PM
Hi,Use a pair of vise grips or a C-clamp to pinch off the hose.This way you can control some of the flow.You shouldn't loose much.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#205917 04/14/2006 9:26 PM
you might have a small gas container around to catch it,or you could plug it up or squeeze the line as mentioned.
Redryder pix
My Hotrod
#205918 04/14/2006 9:58 PM
Since that isn't a high pressure hose you can probably get by with a piece of fuel line and barbed push in fittings available over the counter from NAPA. Bring the old one with you.
#205919 04/14/2006 10:00 PM
#205920 04/15/2006 12:05 AM
and funnel
sorry NM51 but i believe...
be sure you spend the big bucks for a really good fuel (high pressure--injected system) line and DON'T buy the cheap fuel line, it will only over time crack again.
this modern gas we have eats the rubber over time due to the additives.
my .02
Jim & Caroline
#205921 04/15/2006 1:25 AM
Chevy duty has the pre-cut and fit fuel line for $9 plus $7.50 minimum shipping.
I think the modern cut to fit fuel line is made for the modern gas and will rot at the same rate, but since you'd only save about $10 it might be worth it to wait for the pre-cut pre-made chevy duty line. The sponsor of this site might carry it too...
#205922 04/15/2006 3:03 AM
Thanks for the tips. I was unable to find a high pressure replacement, and received the Chevy Duty hose today. We'll see how it goes.
