1 members (klhansen),
90
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2000 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: May 2000 Posts: 69 | 53 Chevy 1/2 ton ---I need to replace the flexible hose that connects the fitting on the bottom of the gas tank to the fuel line. It was leaking from a crack in the hose. The petcock seems to tighten down OK to cut off the fuel from the tank , but my question is: how much fuel can I expect to run out of the line when I disconnect the hose? Will it just be whatever is in the fuel line up as far as the fuel pump, or will gravity drain the line all the way to the in-line fuel filter and the carb? | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Hi,Use a pair of vise grips or a C-clamp to pinch off the hose.This way you can control some of the flow.You shouldn't loose much.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | you might have a small gas container around to catch it,or you could plug it up or squeeze the line as mentioned. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Since that isn't a high pressure hose you can probably get by with a piece of fuel line and barbed push in fittings available over the counter from NAPA. Bring the old one with you.
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | and funnel
sorry NM51 but i believe... be sure you spend the big bucks for a really good fuel (high pressure--injected system) line and DON'T buy the cheap fuel line, it will only over time crack again. this modern gas we have eats the rubber over time due to the additives. my .02
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Chevy duty has the pre-cut and fit fuel line for $9 plus $7.50 minimum shipping.
I think the modern cut to fit fuel line is made for the modern gas and will rot at the same rate, but since you'd only save about $10 it might be worth it to wait for the pre-cut pre-made chevy duty line. The sponsor of this site might carry it too...
| | | | | Joined: May 2000 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: May 2000 Posts: 69 | Thanks for the tips. I was unable to find a high pressure replacement, and received the Chevy Duty hose today. We'll see how it goes. | | |
