Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
9 members (UtahYork, Pre '68 Dave, rfs56trk, Donf, Oldcaliforniakid, baldeagle, J Lucas, Nick in Manitou, Rusted Nut), 36 guests, and 1 robot.
Topics128,005
Posts1,055,253
Members48,418
#205789 04/12/2006 6:37 PM
i'm in the process of switching a 64 chevy pickup body onto a 78 suburban frame and the steering shaft is about 2 in. to long now i'm putting a body lift in but i'm thinking that the steering shaft is still going to be to long and probly not angled right how sould i shorten this steering rod? or would it maybe be best just to swap in a newer style column out of like a 70 chevy pickup or 78 suburban?
thanks
Nate
Link to my photobucket for pics of my vehicles
http://s238.photobucket.com/albums/ff17/OldIronChevy/
#205790 04/13/2006 2:10 AM
Z
Z Offline
the way the power steering kits do it is cut off the flange,use a 5/8"bit to drill through it,then weld it back.the 67 up column has a collapsable shaft you could use.or you could cut the shaft and weld in a u joint.
