8 members (MickeyP, dt235sd, lumbersawyer, Otto Skorzeny, Joe H, 50Chevy3100, 3B, 1 invisible),
67
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,014 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | Hi All, What kind of wheels came on a 51 3/4 ton pick up? Are they spilt rims? They are 8 lug hubs. What are the options for changing to a more conventional hub? I want to put a fancy set of wheels on it but I am sure no one has them! I don't want to got the IFS route because of money and I am hoping there are hubs that will fit the spindle with a more conventional pattern. I plan to change the rear end so that isn't a problem. What do you think? Rick In VA | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I believe AD 3/4 tons came with 15" two piece wheels or with 17" as an option. 8 lug pattern should be the same up to late 90's ? when they went to metric pattern.
Some newer wheels will cause a clearance problem with the front tie rod that you should be careful of because of the offset and width.
You should get plenty of info with a search of the archives as this has been discussed before. | | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | Hi Ghostrider, I am new here and tried to use the search without any luck. When I put in member name, the last item to fill in, all I get is the posts that I have made. I can't figure out how to make it search all members. Can you or anyone help? Rick | | | | | Joined: Feb 2003 Posts: 58 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 58 | From what I've found and if I am wrong, I am sure I will be corrected. 3/4 ton trucks came with the 15" 8 lug wheels, and the 17" 8 lug wheels that were mentioned were more on the 1 ton 3800 series pickups. At least that is the way they came on all the trucks I have dealt with.
Collecting is fun, as long as momma enjoys riding in them.
| | | | | Joined: Apr 2004 Posts: 5,074 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,074 | Rick, You could search the folks listed in the sub-gallery under 1951 . Or use the Search in the Menu bar -- type in "wheels" there is a lot of stuff. Peggy
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | Wow, thanks Peggy. That did the trick. What a resource. Thanks for showing the way Rick | | | | | Joined: Apr 2004 Posts: 5,074 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,074 | Cool. That's a real good search engine!
Peg
