7 members (mick53, Tiny, Southerntruck, HandyAndy, TUTS 59, 2 invisible), 82 guests, and 2 robots.
Topics128,093
Posts1,056,046
Members48,433
#205711 04/10/2006 3:51 PM
Hi All,
What kind of wheels came on a 51 3/4 ton pick up? Are they spilt rims? They are 8 lug hubs. What are the options for changing to a more conventional hub? I want to put a fancy set of wheels on it but I am sure no one has them! I don't want to got the IFS route because of money and I am hoping there are hubs that will fit the spindle with a more conventional pattern. I plan to change the rear end so that isn't a problem. What do you think?
Rick In VA
#205712 04/10/2006 4:12 PM
I believe AD 3/4 tons came with 15" two piece
wheels or with 17" as an option. 8 lug pattern
should be the same up to late 90's ? when they
went to metric pattern.
Some newer wheels will cause a clearance problem with the front tie rod that you should be careful of because of the offset and width.
You should get plenty of info with a search of the archives as this has been discussed before.
Steve
'49 3800
'52 3600
'57 3100
#205713 04/10/2006 8:09 PM
Hi Ghostrider,
I am new here and tried to use the search without any luck. When I put in member name, the last item to fill in, all I get is the posts that I have made. I can't figure out how to make it search all members. Can you or anyone help?
Rick
#205714 04/10/2006 8:44 PM
From what I've found and if I am wrong, I am sure I will be corrected. 3/4 ton trucks came with the 15" 8 lug wheels, and the 17" 8 lug wheels that were mentioned were more on the 1 ton 3800 series pickups. At least that is the way they came on all the trucks I have dealt with.
Collecting is fun, as long as momma enjoys riding in them.
#205715 04/10/2006 8:47 PM
Authorized Pest
Authorized Pest
Rick,
You could search the folks listed in the sub-gallery under 1951 .
Or use the Search in the Menu bar -- type in "wheels" there is a lot of stuff.
Peggy
~ Peggy M
1949 Chevrolet 3804
#205716 04/10/2006 10:08 PM
Wow, thanks Peggy. That did the trick. What a resource. Thanks for showing the way
Rick
#205717 04/10/2006 11:15 PM
Authorized Pest
Authorized Pest
Cool. That's a real good search engine!
Peg
~ Peggy M
1949 Chevrolet 3804
