0 members (),
39
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | What year did two taillights become standard? I'm talking trucks, not cars. I've seen a '48 recently with one, and a '56 with two, so I'm figuring sometime in the early '50s, maybe. Anyone know for sure?
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I had a 55 1st panel with one taillight. I believe 55 2nd had two.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | on the panels, 2 tail lights started with 55 2nd [3 actually because the 55 still had the door mounted light of the AD's as well] - on the stepside pickups the 2nd light was an extra-cost option all along until the 60's sometime - Cameo and fleet's always had 2
Bill | | | | | Joined: Nov 2003 Posts: 285 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 285 | If memory serves me right, only one tail light came on the '56 truck, UNLESS you got the optional step bumper--then that moved the license plate to the center of the truck, instead of the left side, and a second light was added to the right. With this opetion you could also get turn signals.  | | | | | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | My 59 had only the left tail light. The P.O. went ahead and installed the right tail light in 1989.
Cliff59 | | | | | Joined: Feb 2006 Posts: 70 Member | | Member Joined: Feb 2006 Posts: 70 | here is a thoughti might swap out the 2 62 burbs lite for 84 caddy lite anyone done this yet
bill
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | 1960 is the first year turnsignals are required to get an inspection sticker in Texas. I would gather by that 2 taillights became mandatory that year. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Originally posted by red58: on the panels, 2 tail lights started with 55 2nd [3 actually because the 55 still had the door mounted light of the AD's as well] - on the stepside pickups the 2nd light was an extra-cost option all along until the 60's sometime - Cameo and fleet's always had 2
Bill 2/3 taillights were available from 47 on unit bodies. The 55.2 models were the first ones were it was standard. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | ....... The 55.2 models were the first ones wHere it was standard. wasn't that the original question I answered [ What year did two taillights become standard]? Bill | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Heck most of the cars and trucks in this town only have one tail light! (Headlight too!) | | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | Mine doesn't have any working lights at all. | | |
