2 members (qside, 78buckshot),
76
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,072 Posts1,055,907 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20516 03/27/2003 6:56 PM | Joined: Mar 2003 Posts: 5 Member | | Member Joined: Mar 2003 Posts: 5 | I just got an oil filter canister for my 235.What do I do about the oil pressure gauge line that is connected to one of the outlets in the block that the filter lines go to?
#20517 03/27/2003 7:45 PM | Joined: Jul 2000 Posts: 580 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 580 | Hi John, You need to get a tee fitting so you can connect both the oil pressure gauge fitting and the oil cannister inlet fitting to the rear-most connection on the block. Here is a link to the Factory Assembly Manual Oil Filter Instruction page. | | |
#20518 03/27/2003 9:28 PM | Joined: Mar 2003 Posts: 5 Member | | Member Joined: Mar 2003 Posts: 5 | Thanks Larry,I figured it was somthing simple like that.
