0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#20418 04/25/2005 10:04 PM
How often and how should I lube my '71 and '79 4x4 cv joints? :confused: The books say "frequently", with special GMC lube and special tool to access the special fitting. Will chassis grease in a needle point do it? How often? Thanks,
Ray
#20419 04/25/2005 11:52 PM
Frequently!
Seriously...makes me think of "define "is". HA!
One thing I do know is that "SPECIAL GMC lube" is only special becuase they want to sell it to you. If your needle point will get in there then GET'ER DONE.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#20420 04/27/2005 9:16 PM
RG Offline
Junior Member
Junior Member
RPG52,
From my years of owning both Chevy's and GMC's currently a 83 and 87 one of both. along with Jeeps,the CV joint on the transfer case end of the front propeller shaft gets chassis lube twice per year. Spring and fall. I live in snow country, and run in 4x4 at least once per month during the winter months. I have traveled 600 miles in one shot in 4x travelling 60-65 MPH.
The 87 has 65K miles and the 83 close to 280K.
I have not replaced a CV joint yet. If you can see clean/fresh grease where the ball is you should be fine. If not. insert the needle, pump in some new, until its visable at the ball end.
I've have wheel bearings fail in front do to water contamination. Now I clean and repack every 30K miles or 3 years. (Hubs, spindles, cross joints, and wheel bearings).
