7 members (Otto Skorzeny, Southerntruck, Guitplayer, Hotrod Lincoln, 52Carl, qside, 1 invisible),
160
Mod | | | Forums66 Topics128,087 Posts1,056,115 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20418 04/25/2005 10:04 PM | Joined: Mar 2005 Posts: 17 New Guy | | New Guy Joined: Mar 2005 Posts: 17 | How often and how should I lube my '71 and '79 4x4 cv joints? :confused: The books say "frequently", with special GMC lube and special tool to access the special fitting. Will chassis grease in a needle point do it? How often? Thanks, Ray | | |
#20419 04/25/2005 11:52 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Frequently!
Seriously...makes me think of "define "is". HA! One thing I do know is that "SPECIAL GMC lube" is only special becuase they want to sell it to you. If your needle point will get in there then GET'ER DONE. | | |
#20420 04/27/2005 9:16 PM | Joined: Mar 2005 Posts: 10 Junior Member | | Junior Member Joined: Mar 2005 Posts: 10 | RPG52, From my years of owning both Chevy's and GMC's currently a 83 and 87 one of both. along with Jeeps,the CV joint on the transfer case end of the front propeller shaft gets chassis lube twice per year. Spring and fall. I live in snow country, and run in 4x4 at least once per month during the winter months. I have traveled 600 miles in one shot in 4x travelling 60-65 MPH. The 87 has 65K miles and the 83 close to 280K. I have not replaced a CV joint yet. If you can see clean/fresh grease where the ball is you should be fine. If not. insert the needle, pump in some new, until its visable at the ball end. I've have wheel bearings fail in front do to water contamination. Now I clean and repack every 30K miles or 3 years. (Hubs, spindles, cross joints, and wheel bearings). | | |
