2 members (Simon1954, KingG),
56
Mod | | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | In cleaning up my single action shocks ('40 GMC) the book says to replace the lead gaskets around the drain plug, as I call it, with new. Lead has become such a no-no, unless you're a fisherman, that it's almost impossible to find it anywhere. Can I just use regular gasket material on these or will they become saturated and start leaking?
Neil 1940 GMC 1/2 Ton
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Are they crush washers or actually a rolled gasket? If they are crush washers they are available, but they make them out of copper nowadays.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | They look like a rolled gasket to me, but I thought about trying to find some aluminum crush washers to use. I didn't know they made copper cruch washers. Where can you find them?
Thanks Josiah!
| | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 |
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | Thanks for the link 41Chevy. I should have thought about McMaster myself. They have virtually everything.
| | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | I have lead washers i can mail, if they work. Hole= 9/16, outside= 15/16, thickness= 3/32. contact me at work, 601 liverpool ave. Egg Harbor City, NJ 08215
"It ain't a truck if you can't hose out the cab."
| | | | | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | Wow! Thanks Chester! I'll check the dimensions tonight and let you know. I only need 4. Let me know how much you want for them.
| | | | | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | Thanks Chester. I'll PM you with my address. Those dimensions should work just fine.
| | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | i put a half dozen in the mail. how long from nj to you? hope they fit your need.
| | | | | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | Thanks again Chester. Should only be a few days to get to me.
I really appreciate it.
