Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (Frank50, 55shaker, 1955 1 Series), 48 guests, and 2 robots.
Topics128,006
Posts1,055,272
Members48,418
#203878 03/16/2006 7:35 PM
In cleaning up my single action shocks ('40 GMC) the book says to replace the lead gaskets around the drain plug, as I call it, with new. Lead has become such a no-no, unless you're a fisherman, that it's almost impossible to find it anywhere. Can I just use regular gasket material on these or will they become saturated and start leaking?
Neil
1940 GMC 1/2 Ton
#203879 03/16/2006 7:43 PM
Are they crush washers or actually a rolled gasket? If they are crush washers they are available, but they make them out of copper nowadays.
Paint & Body Shop moderator
#203880 03/16/2006 7:49 PM
They look like a rolled gasket to me, but I thought about trying to find some aluminum crush washers to use. I didn't know they made copper cruch washers. Where can you find them?
Thanks Josiah!
Neil
1940 GMC 1/2 Ton
#203881 03/16/2006 8:50 PM
Here try this link: http://www.mcmaster.com/
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#203882 03/16/2006 9:16 PM
Thanks for the link 41Chevy. I should have thought about McMaster myself. They have virtually everything.
Neil
1940 GMC 1/2 Ton
#203883 03/16/2006 10:39 PM
I have lead washers i can mail, if they work. Hole= 9/16, outside= 15/16, thickness= 3/32.
contact me at work, 601 liverpool ave. Egg Harbor City, NJ 08215
"It ain't a truck if you can't hose out the cab."
#203884 03/16/2006 10:49 PM
Wow! Thanks Chester! I'll check the dimensions tonight and let you know. I only need 4. Let me know how much you want for them.
Neil
1940 GMC 1/2 Ton
#203885 03/17/2006 7:17 PM
free
#203886 03/20/2006 5:53 PM
Thanks Chester. I'll PM you with my address. Those dimensions should work just fine.
Neil
1940 GMC 1/2 Ton
#203887 03/22/2006 11:17 PM
i put a half dozen in the mail. how long from nj to you? hope they fit your need.
#203888 03/23/2006 12:49 AM
Thanks again Chester. Should only be a few days to get to me.
I really appreciate it.
Neil
1940 GMC 1/2 Ton
