2 members (Bill Hanlon, Steelonsteel), 131 guests, and 2 robots.
Topics128,062
Posts1,055,854
Members48,428
#2036 07/19/2003 5:54 AM
Junior Member
Junior Member
I have a 327 I am planning to put in my '46 Truck, can anyone tell me what rearend will fit? I would like to keep the 6 bolt pattern if possible.
I am also planning to keep the stock front suspension, will I be able to keep the stock steering box with this motor?
#2037 07/19/2003 6:11 AM
Welcome to the Stovebolt cool
I believe the full size blazers and some of the Jeep pick-ups and full size Cherokees will have what you are looking for. Some of the Jeeps had two different track widths and I fight with brain-cells at the moment to recall which fits better(wide or narrow track). The Blazer I am told is real close but to fit the original pick-up half-ton springs you will have to get some new spring mount pads and weld them on in the proper angle for the springs as they are angled on the rear(narrow at the front and wide at the rear)
