| | | Forums66 Topics128,048 Posts1,055,663 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 3 Junior Member | | Junior Member Joined: Jul 2003 Posts: 3 | I have a 327 I am planning to put in my '46 Truck, can anyone tell me what rearend will fit? I would like to keep the 6 bolt pattern if possible. I am also planning to keep the stock front suspension, will I be able to keep the stock steering box with this motor? | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Welcome to the Stovebolt I believe the full size blazers and some of the Jeep pick-ups and full size Cherokees will have what you are looking for. Some of the Jeeps had two different track widths and I fight with brain-cells at the moment to recall which fits better(wide or narrow track). The Blazer I am told is real close but to fit the original pick-up half-ton springs you will have to get some new spring mount pads and weld them on in the proper angle for the springs as they are angled on the rear(narrow at the front and wide at the rear)
