1 members (tesa),
59
0
Mod | | | Forums66 Topics128,076 Posts1,055,925 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20354 04/28/2005 6:10 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Hey guys, The starter in my 235 dosent engage it just spins. Any suggestions? Can I replace anything on it or do I have to replace the whole unit? The first time I tried to turn it over it turned the motor over (saw the fan blade moving) and then after that it only spins
Thanks, Bill | | |
#20355 04/28/2005 6:57 PM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Make sure you have 12 volts to it. If so, then remove the starter and disassemble. Clean or replace brushes if needed. Use wet dry sandpaper to clean up all the magnets and contacts. reassemble and install. I did this with mine and it worked like new. Hope this helps. | | |
#20356 04/28/2005 7:44 PM | Joined: Mar 2005 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 85 | If the starter is spinning and not "engaging" wouldn't that be a solenoid problem not a motor problem?
shawn | | |
#20357 04/28/2005 8:07 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Thanks Bullnose, Where did you get the brushes? | | |
#20358 04/28/2005 9:29 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Replace the drive gear on the end of the armature. It has an overuning clutch in it that gets worn. The parts are available at any parts store & easy to put on.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#20359 04/28/2005 9:30 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | I'm assuming it would be called a starter rebuild kit? | | |
#20360 04/28/2005 10:09 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They sometimes are available like that but usually come in the individual parts. Tear it down & see what you need. Sometimes the brushes are OK. Check the bushings also. You can take the cap off the selenoid & clean it up. If the main terminal is worn or burnt you can turn it around & use the other side. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#20361 04/29/2005 12:52 AM | Joined: Feb 2004 Posts: 29,778 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,778 | The starter drive has already been mentioned, and it's the most likely cause. However, here's a sneaky one that most folks overlook. Check out the shift fork that connects the solenoid plunger to the starter drive. The pivot pin, and/or the two fingers that transmit the movement to the starter drive can get worn to the point that the solenoid switch gets made before the gear engages the flywheel. It's not uncommom to find material welded onto the fingers of the shift fork on a rebuilt starter. Jerry
#20362 04/29/2005 1:36 AM | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | No one asked if it's a foot operated mechanical set up or uses a solinoid like PG and V-8 models. | | |
#20363 04/30/2005 2:26 PM | Joined: Jun 2003 Posts: 41 Junior Member | | Junior Member Joined: Jun 2003 Posts: 41 | Most have an adjustment on the throw out for the Bendix, check in an old repair manual and it will give you the details. | | |
#20364 04/30/2005 3:18 PM | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | Chevy doesn't use a Bendix starter,it's an over running clutch drive ,although people call them all Bendix's.A Bendix drive is self engaging,like on old Fords. If it's a foot operated mechanical linkage,the problem is often lack of enough throw because the cab has sagged on it's mounts.Or the overrunning clutch drive is worn or the gear teeth are history. | | |
#20365 04/30/2005 4:43 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Pulled the solenoid off yesterday and found that one of the copper wires (one of the two that are together) was broken. I brought it to work today and I'm going to attempt to solder it. If that doesn't work I'm going to buy a new $30 solenoid from Michel Waltrips store.
This has been fun and educational. I didn’t realize one could do so much work on a starter them selves. All my life (30 years) I have always seen people just shell out money for a new one. Thanks for the Help guys! If this doesn't work Ill be back! Ill be DARNED if I'm going to buy a new one! Plus the new ones are probably HECHEN IN MEXICO. | | |
#20366 05/03/2005 3:31 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Well, Michel Waltrips starter solenoid worked out great. Now I need to run a remote fuel tank, change the points, distributor cap and prime the fuel line. By the way... the Solenoid was MADE IN THE USA.
What weight of oil should I use in it? The motor has either 25,000 or 125,000 or 225,000 miles. Looks to me to have been rebuilt at some time. Should I spray the carb inside with carb cleaner or some sort of other cleaner? | | |
#20367 05/03/2005 5:18 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | When I had my engine rebuilt a little over a month ago, the rebuilder recommended SAE 30. He said the 235 were not designed with multi-viscosity oils in mind.
Personally, I don't like to spray carb cleaner unless the carb is apart. I know Rochester B's don't have any rubber parts, but later model carbs do. Carb cleaner will attack those rubber parts and turn them to goo. I also don't know what it will do to the leather accelerator pump diaphragm.
Oh, and congrats on finding the solenoid made in USA!
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
