0 members (), 132 guests, and 2 robots.
Topics128,157
Posts1,056,876
Members48,458
#203594 03/12/2006 2:49 AM
Z
Z Offline
i can get it for 75 dollars.i know the later ones are better,but can this be updated cheeper than buying a later one?
#203595 03/12/2006 3:01 AM
Go for a little later model.
#203596 03/12/2006 4:44 AM
During rebuilds you can add or change whatever it is that updates the older ones to be as good as the new ones. I don't know what is changed for sure. Ask a tranny shop what year the improvements were made. Ask, why is it out of vehicle now, were there problems?
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#203597 03/12/2006 6:21 AM
What about one from an '86 GMC?
#203598 03/12/2006 7:16 AM
The best ones started in 87, but the older ones are not exactly garbage and if it works, you are already ahead. I had one rebuilt and at the last minute my guy found me an 87, but I had supplied him with an 84.
#203599 03/12/2006 7:17 AM
I know that the early ones had some problems, but for $75 I bet that you can fix any issues it does have. Sounds like a good buy to me.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#203600 03/12/2006 7:52 AM
Z
Z Offline
he said he bought a van with a 305 for the engine,then scrapped the van.
#203601 03/13/2006 8:43 AM
The key on these trannys is to make sure you set the TV cable correctly. It doesn't just kick down the automatic for passing like a TH350. Instead it helps tell the tranny what the load is for throttle desired. Its much more sophisitcated and if not set right will burn up the tranny. Get a shop to look at it or go to www.bowtieoverdrives.com for info.
#203602 03/13/2006 12:34 PM
At $75.00 it is at a minimum a very good price for a core. Most places charge $95-100. Plus it can be upgraded to the newer (stronger) parts.
#203603 03/14/2006 6:47 PM
I had the 700R4 as original equipment in my '85 Suburban, had nothing but trouble with it. I finally had to take it to a speed shop for a total rebuild. It cost me major bucks. Spend a little extra and get a later model 700R4, is my advice. You ought to be able to pick up a core for $20 at a junkyard.
#203604 03/17/2006 2:45 AM
I have a completly rebuilt 700 R4 with a 2200 stall converter $850. plus frt.
48 Chevy 3100 Shortbox 5 window
"The Big Dog"
