| | | Forums66 Topics128,194 Posts1,057,263 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 10 Junior Member | | Junior Member Joined: Apr 2005 Posts: 10 | It was 3 years ago that I took it off and now I can't figure out how to put it back on again. I don't have power steering or AC. Am I right to assume that it hangs to the driver side? Othere than the slotted double adjuster bracket, there is an offset, bent bracket with two holes at the offset end and one hole at the other end. Where do I position this?
Thanks a bundle,
Rick | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | alt should mount off the drivers exhaust manifold on that offset bracket - the single hole on the slotted piece will fit on one of the waterpump mounting bolts, usually w/ a bolt that has a nut an inch from the end rather than a regular head - the bolt holds the pump, bracket fits on the threaded end left exposed, held on w/ a nut - the slotted part attaches to the top of the alt and is the adjustment to tension the belt not great pics, but like this and like this Bill | | | | | Joined: Apr 2005 Posts: 10 Junior Member | | Junior Member Joined: Apr 2005 Posts: 10 | Thanks Bill, It's hard to tell, but does your alt mount bracket have a 90 degree bend in it? All three of the holes in my bracket face the same way. Will it still mount on the driver's exhaust manifold?
R | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | On my '67 (alt only), there is a bolt that runs through the base of the alternator into the front of the driver's side exhaust manifold. The bracket on mine bolted to the water pump housing, but that bracket was not the original, so it looked a little funny, but functioned just fine.
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Rick - you got the truck and parts in front of ya, only you can see if it'll work similar to the pics I posted!! I can't see what you have to suggest what might be missing or which direction anythig fits
need something to mount one ear of the alt to the manifold, and if you hang the alt up by the top adjusting [slotted] bracket, you should be able to hold bits and pieces between the bottom of it and the manifold and see what's what
Bill | | |
