5 members (papas52, Bills Auto Works, Napco Man, Shade Baby, LAROKE), 171 guests, and 1 robot.
Topics128,102
Posts1,056,184
Members48,436
#202343 02/27/2006 5:03 PM
I've had the displeasure of changing tires on rims here in the yard, with nothing more than a small assortment of prybars and tire irons to work with.. one of the toughest things was to break the bead on the tires.. The only method I found that worked half decent was to lay the tire flat under the bumper of a car, put a board on it, then sit a bottle jack on the board and jack up the car.
Quite a pain in the @$$.
So as luck would have it, a few weeks ago at the local auction I bought an apparatus called a "bead breaker" for $35.. man this thing is the cat's pajamas!
Lay the tire on it, push down on this bar, and what used to take me an hour happens in less than a few seconds!!!
Getting the tire off the rim after the bead is broke loose still presents a time consuming challenge.. but i'm betting theres a special bar or tool that makes that process alot faster.. any of you old school guys know what it would be called?
Yea, yea.. I know you can take a tire to a place and get it mounted and balanced for $10.. but there are times when it comes in real handy to be able to swap a tire at home without having to drive into town.. especially when the only vehicle you have at the time is the one that needs the tire!!
#202344 02/27/2006 5:17 PM
I've always called them a tire iron or a tire spoon, the end is curved to make it easier to dismount,look at tractor supply,napa,co-op,,brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#202345 02/27/2006 5:37 PM
I
I Offline
Northern tool has Bead breakers
You should also get yourself 2 of these.
Tire spoon
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
#202346 02/27/2006 6:04 PM
If you do this often I'd suggest you keep your eyes open at the swap meets for an old manual tire machine.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#202347 02/27/2006 6:08 PM
L Online: Content
A manual tire changer and a static balance machine are also available from Harbor Freight. Each of them for about $70. This "how-to" article shows them both in action, Fumblin'.
Wheel Restoration
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
#202348 02/27/2006 6:44 PM
We used one of those old lever action bead breakers when we changed the tires on Number Seven. Works like a champ.
We've also got a homemade tire spoon that we used to put the new ones on. It looks like a piece of a girder ground into a rounded shape (and with a handle ground into the end) and the end that you stick in the tire is curved. We were reusing the split rims, though, so they didn't need much finagling.
#202349 02/27/2006 7:20 PM
Great article Larry.
Professional Novice
